DC motor question
lumphammer
21 Aug 2003
Chichester
The motor on my lavac pump died on me this morning, there is no problem with the supply. Taking the motor apart I could see there are three carbon brushes two bigger than the third.
The smaller brush is worn so much that I thing that is the problem, but I'm a bit confused as to why there are three brushes.
On the rotor opposite pairs on the commutator are connected, and these connect to the two thicker brushes. The smaller brush is at 90 deg to the other two
I've ordered a new carbon brush to replace the worn one, but I would like to understand why three brushes.
Plum
6 Jun 2001
UK East Coast
Interesting, not come across this before but out of curiosity found this US3497788A - Variable speed d.c. motor with third brush - Google Patents may or may not be relevant
Alex_Blackwood
19 May 2003
Fareham
The third brush is for the field winding. If that was worn and not making contact it would explain your dead motor 🥴 There are on line references if you want to look up "DC motor third brush" Most refer to dynamos but same circuit for motor. They are basically the same thing.
