Dave100456
Hi
Any suggestions pls re a pump that’s not working. It has worked reliably for a year and nothing has been changed.
It’s a DC Flexible Impeller Pump driven by a 12v motor.
one of these. https://www.spxflow.com/en/johnson-pump-marine/pd-marine-DC-driven-flexible-impeller-pumps/
Turn it on and it self primes taking less than one second or so. Then it pulses for a fraction of a second every two or three seconds.
When the impeller cover plate is removed or the whole pump body is removed the motor will run ok. There’s no mechanical obstruction to the impeller turning.
The electric motor shaft can be turned by hand but is notchy.
Is it a faulty electric motor that isn’t now producing sufficient torque?
Have emailed Johnson Pumps but won’t get an answer until next week. Any advice here appreciated.
Thank you
Dave
Thank you
Dave
