Storyline
Have decided that we really have to come up with a solution to transporting our dinghy. It is too long to fit between the baby stay and the mast and we have had the classic flying dinghy syndrome a couple of times in strong winds so some time ago we gave up towing it completely. Now we have to inflate it (not too much hassle) but then haul it aboard using the spinny halyard and then deflate it after use which is a pia when we only want to do a bit of shopping. As a result, age and a gradual dimming of the excitement of getting the tender out as soon as we arrive somewhere means we sometimes anchor and then do not get off the boat for a walk/explore etc.
The obvious solution seems to be davits but a few questions arise;
The dingy is not set up for use with davits so I am not sure how to modify it to include lifting points. It has an air deck with a ring near the bow but this would not be suitable so how do people lift the bow ? The stern has a wooden transom so I assume I can just drill a hole in that.
As regards the davits, are there any particular models that are recommended ? The deck at the stern of the boat is quite busy with the normal taffrail stanchions and a pole for a wind generator on stbd and a crane for the outboard on port so I was wondering if there was something available that mounts through the transom rather than vertically onto the deck. The boat is a traditional design with a near vertical transom.
Is the lifting system just a block/s and purchase or are there better/easier to lift solutions ?
Any tips gratefully received
(The hinge type system I have seen widely used would not be suitable as the engine exhaust is through the transom).
The dinghy is a hefty Avon Rover 2.8 airdeck which weighs in at 36kg.
Edit: thinking about it maybe an alternative is to get a secondary ultralight weight dinghy for use to row when it is calm. These days there is usually just the two of us so something small would suffice for a quick shopping trip. However I really like the security of having something substantial when it is a bit rough or when I am going outside the anchorage to lay the pot. I am very careful when using it in offshore winds and never have to completely rely on the engine but in even moderate winds waves can develop sometimes if we have to anchor some way off the shore. Is a secondary lightweight option complete madness ?
