Daydream believer
On Friday 18 June 2021 I was SH en Route from Bradwell to Ramsgate & sailing in company with a Leisure 27 ft bilge keel yacht with about 1.200 draft which we will call SN to avoid any embarrassement to the owner
My yacht Daydream Believer is a Hanse 311 with 1.75 draft.
Wind was roughly NE 22Kts
the time I got to the Knoll I was already vomiting. To make matters worse my Raymarine AV 100 autopilot had finally failed & my boat being directionall unstable meant that I could not let go of the helm. I could not turn back to Bradwell as not enough water & I could not let the sails down & motor to shotley Which I would have preferred.
So I carried on by following SN
30 mins from the crossing I heard the radio call from a 42 ft bavaria "P" telling Dover CG that she was aground on the southern side along with anotherlarge ketch "S"
P's VHF was rubbish & Dover had to keep asking for repeats & the lady on board was having difficulty & extremely worried as the yacht was well aground. Dover also kept asking lots of low key questions & I suspect this lead to a delay in calling a lifeboat. I did note that one question- what safety equipment do you have - answer life jackets then-- anything else- was left with a blank response!!!.
Dover made thing difficult by insisting on coordinates which took numerous transmissions . The ketch did not give any transmission as it later became obvious to me that its vhf was virtually inoperative & P was relaying messages to Dover.
To make matters worse S had pressed her AIS alarm & every few minutes a MOB signal flooded my chart plotter. This had to be cleared & being sea sick I managed to turn the plotter off which took several goes to turn back on. Every few minutes I had to clear the signal that came right across my Garmin.
I had vomited a further 2 times by then
It ried to call SN to tell him of the situation & tell him to stick to Tillergirls waypoints & not try to help as we could never do anything to help. However, he either did not hear or ignored my suggestion. S replied to one of my calls but the signal was so distorted that I then gave up as he was destroying any attempt to contact SN
By this time I was level with SN & we entered the swatchway.
To my utter amasement SN sailed towards S where there was clearly a line of breaking surf.
He sailed into the surf & ran hard aground in the swell. I saw his rudder come out of the water . The boat then rounded to stbd & it rolled such that it tripped over the port bilge keel & rolled on its side. Fortunately a couple of waves later the stbd keel pulled it back onto its 2 keels.
By this time I was half way through the channel & was vomitting. I let go of the tiller & the boat did a 360 & I got trapped in the mainsheet as it gybed.
I lost all orientation & whilst I had been following tillergirls 2019 waypoints I did get of course for a few minutes.
My depth went down to 300mm below the keel when I did get back on couse as I exited the channel. I exited around 12-00 & 12-05 ( Walton LW 11-46) BST
A large tug had arrived but could not enter due to depth so FINALLY Dover decided to call Walton & Clacton lifeboats who were on the scene in about 30-45 minutes.
SN actually managed to motor off in the swell because the bow turned to deaper water. The life boats attended to the other 2 & followed them North. SN carried on to Ramsgate. By then she established that she had damage to the skeg & was leaking, A damaged rudder but could later return to Stone where she will be hauled out for repair this week.
When we looked at the navionics chart a couple of points come up that I think east coast sailors should be aware of.
S was transmitting ais as MOB. This lead SN over to her . She could see the wind generator & radar pole & thought it was someone on the stern. The navionics showed her to be in 6 M of water when in fact she was aground. S should NOT have sent MOB signals
SN logged the position where she grounded. The latest navionics shows 6M which demonstrates that the sands have shifted considerably
When SN returned to Bradwell she reported ample depth by following Tiller girls latest waypoints when crossing a couple of hours after LW. I returned via the norther crossing towards Barrow No2 which I much prefer. Longer but I like being able to see reference points rather than rely on GPS
So the point of this is the AIS alarm was wrong & the navionics chart of the sw sunk is wrong-- Could have done that in one line I suppose
SW Sunk stranding
2010 to 2020 comparison
