Wansworth
Bitter end of chain was not lashed to ring in anchour locker.........let out full scope,literally!Bitter end ?? How much cable did you let out ???
Or do you mean anchor stock wasn't shackled to rode ?
That’s alright,it’s a sort of confession,managed to re. Anchour with spare anchour and rope rode!I didn't mean to seem 'clever' - its just unusual to hear someone lose it all !! So wondered if you got Bitter End mixed up with the shackled stock.
I've seen a ships anchor and cable rip out bitter end ... that is something you hope never to see .... the damage it does is truly mind blowing.
Borrowed the clubs fireball ,me and my brother out of Litttlehampton in a strongish sw ......ended up down wind and tide as could not hold the bugger down so cobbled up a reef in the main and fought our way back............class captain,for it was her,admonished us but she was as heavy as us both together,although I didn’t say,being a gentleman!Painting the boat one season, me and misses half way round, I sent daughter to get another tin of paint, she came back saying that they don’t make our color anymore, for some unknown reason we started painting faster! With what we had left.
another big mistake was trying to sail a fireball on my own, the wind was light on shore, but blowing further out.
finished up sailing down wind till I could get ashore.
I know that gravel boat that picks up from a dock in Fareham and takes it to Newport. It is so silent that sometimes I have looked back in Portsmouth Harbour and there it is right behind me. Quite scary.Rowing back to the pontoon moorings with my wife midweek after an evening in the Folly Inn.
It was a beautiful night, not a breath of wind, neap tides, nothing stirring on the river.
As we neared the pontoon the lights of the Folly Inn suddenly disappeared as if a curtain had been pulled across. WTF? I looked up and to my horror saw the steaming light of a coaster as it slowly passed up river crossing our wake where we had been seconds before.
Only after it passed did we see hear the slow thump of the engine and the trickle of it's wake.
That got the heart pumping!
Yes fishing is scary stuff - respect.Bit difficult to explain, but using a whipping drum, or capstan pot hauler, there is a method for passing the 'legs' or lanyards spliced into the backrope without removing the, sometimes seven, turns. The drum is horizontal on a casing in front of the wheelhouse, midships, french style. You drop the lanyard over the end of the drum each time it comes round.
Any old how, I was working the drum, hauling the first end, the rope was five times round and the end anchor had come fast in the bottom just as a plastic ball float on a strop was round the drum. They always do that. It's because the ball is a 'watcher' designed to appear at dead slack low water if the rest is cut off. Trying to get the hitch out, leaning over the drum to get a pull, boat jumping about, suddenly went up, rapidly, whipping the ball off the drum and straight up into my face. A snaggle tooth went through my lip, I could blow bubbles of blood through the hole, much to everyone's amusement. I grew a beard to cover the scar.
Other crewman did nearly as bad, he got a riding turn as the pot came up to the gunnel roller (variously known as a molgogger or buljowler depending on which port you're from). the pot came over the rail, and went round the drum as he sat down very quickly, leaning back as the pot whipped past his nose before disintegrating after a few turns. French wood barrel pot, fortunately, steel would have done some damage.
He couldn't get away because you had to flake the backrope all around trapping your legs and feet, and dare not move them even if you could, otherwise you might step in a loop as the rope surged out, hauling your leg into the capstan.
I found that taking up gliding instilled in me a far stronger check-it-before-you-need-it attitude than I had before. Final approach is no time to find out that your airbrakes have frozen shut. So, like you, I always check forward and reverse power before leaving, and on longer trips the main stays loosely bundled in a millipede along the boom. It doesn't look as neat as a harbour stow under the cover, but we can have it up in a minute or so.The incident also reinforced in me the habit of checking steering full lock to full lock and that we have f'wd and astern propulsion before letting go lines. Sails bent on and ready to go is a given and it makes me very nervous to be at sea in a sailing boat with the mainsail cover all on and triced up.
So out we went, Dorus Mor in our sights. Our speed didn't quite seem as high as we had expected. Then we saw the first of the boats coming the other way. What a bunch of dafties, we said to each other. Even that Centaur that, according to AIS, was doing 7kts straight towards us. Oh hang on. I re-ran my tide calcs. And, yes, I had read off the LW time instead of the HW. Couldn't have got it more wrong if I'd tried.
Something I learned when leaving Aberystwyth one day ... I suspect the same applies at other harbours, so I have made a rule out of it:
If the waves are breaking over the harbour wall, it was probably a mistake going out ...
