Stemar
The cheap and nasty FM radio on Jazzcat has died, so I've got a Kenwood DAB/DAB+ radio. The DAB antenna supplied is a stick on the window job and has an amplifier with it, which appears to be powered through the single antenna lead and has a ground tape than the instructions say needs to be stuck to the metal windscreen pillar. No mention of baring the metal or anything. Jazzcat is, of course, GRP, but has aluminium window frames. Can anyone tell me if sticking the ground to one will do the job, or do I need to run a lead to the battery -ve?
Supplementary question: the rather cryptic set up instructions talk about setting crossover type, which can be 2-way or 3-way. The only crossover I know of is in multi-speaker enclosures, and I haven't got anything so fancy. Can anyone enlighten me about this, please?
Thanks in advance
Thanks in advance
