D6 Heat Exchanger weeping
whisperjet
20 Dec 2009
The heat exchangers on my D6, showing signs of weeping, white crusty build up, heard it is not uncommon, anyone else had this, was it a big job to cure or just the seals.
volvopaul
1 Apr 2007
midlands
hotmail.co.uk
A common problem along with marine growth inside causing a blockage and partial overheating , answer is to remove and strip the coolers down to do a proper job, some on here clean with chemicals but you still need to replace all the o rings which means a strip down unless you just want to change the end caps o rings which can be done in situ.
