DownWest
I posted this before, but a similar prob on an older VP/Perkins three pot was due to the vent from just under the filler cap to the header tank, becoming blocked. Kept air in the circuit that caused it to over heat.
I'm happy to have stumbled onto this discussion. My D1-13 has also been overheating intermittently and unpredictably for most of the time that I've owned it. There seems to be a bleed screw on top of the freshwater pump, but it only bled coolant when I opened it. I'll try raising the expansion tank and see what happens.I had the expansion tank on my new D1-13 raised after 12 months of intermittent problems. I found that motorsailing on a port tack will definitely make it overheat, motorsailing on a starboard tack will definitely clear the overheat and on the flat, anything could happen. Try that and you will know whether you need to raise the tank.
Hi, I'm having issues with my D1-30. Steam coming from the wet exhaust and obvious bubbles in the raw water pipe work. I'd like to read your blog page but the link isn't working? Thanks TonyGood point - I'm definitely raising the expansion tank on Arpeggio this winter.
I put together a blog page about my investigations here, which people might find useful. I think I've got the permissions correct on the page so that it's publicly readable!
Thanks, I've just posted a forum entry on the issue including links to videos which show the bubbles and the water flow. I don't think I'm getting as good flow in the exhaust as I used to, particularly when the engine is pushed over 2500 revs.Unfortunately the blog site is no longer active - sorry!
If you've got steam coming from the exhaust, sounds like not enough water getting through the raw water side of the heat exchanger. Bubbles in the raw water pipework could well be linked. How much water is coming out of the exhaust? Should be regular gushes of good flow.
