jlavery
I know there are several threads on overheating Volvos, but want to distil my experience and garner some advice.
Symptoms:
James
Symptoms:
- Engine been running fine for some time, but recently has had overheat alarm after running at more than 2,000rpm for a long period (1 hr).
- When up to temperature but not alarming, engine seems hotter than should be to the touch, but runs fine.
- Raw water system is fine. Good flow.
- Raw water out through exhaust seems unnaturally cool, would expect it to be hotter.
- When engine up to temperature, can see coolant entering expansion tank via the thin (overflow/relief?) pipe
- Coolant pump turning find, and belt tension seems OK.
- I've taken front off the heat exchanger and it looked OK. Ran a coat-hanger through holes to clear any debris if there was any I could see.
- Heat exchanger blocked at other end? -> Should I remove completely and check?
- Coolant pump broken? -> How can I check this?
- Thermostat not opening? -> Check this by removing and seeing if it opens in a pan of hot water? Do I need a thermometer to check operation temperature?
- Other?
James
