CW or CCW??
ST840
22 Jun 2014
Southampton
I have a starfisher 840 on a single shaft drive.
Id like to remove the propellor, but can’t shift the nut. How do I determine which way the nut tightens? I’m pretty sure my prop turns CW, so does this mean the nut tightens CCW?
Apologies if this is a silly question.
The nut tightens clockwise so counter clockwise to remove. Make sure your spanner is a really good fit and support the horizontal blade to the left in the picture on a block of wood.
www.solocoastalsailing.co.uk
Thanks very much, I have been blocking the prop blade with wood, but just can’t get the nut to budge. Hence the question. Wasn’t sure if I was tightening the nut by mistake.
Try putting some heat on it, a good blowtorch should do the job. It needs to be nice and hot.
