Plum
No reason at all as long as there is enough space between the prop and bearing to allow a flow of water to lubricate the cutless after allowing for the prop to move forward as the engine mounts/coupling to compress. I drill a 6mm diameter hole side to side near the end then leave 15mm of the cutless protruding. I have made a tool to extract using those 6mm holes.Is there any good reason why Cutless bearings are pushed in flush to the housing?
Having the bearing protruding by 10mm or so would make life so much easier to extract it.
www.solocoastalsailing.co.uk
