Poignard
It certainly is happening: https://edition.cnn.com/2025/04/11/climate/trump-noaa-budget-cuts/index.html
I think Trump and his myrmidons know perfectly well what they do; and they are happy doing it!Were I religious, I might say, “Forgive them, O Lord. They know not what they do”![]()
Sadly, Frank, some of them do but are doing it anyway. I have wondered, and maybe you can advise, how dependent is the ECMWF on data from the US?".... They know not what they do”
I do not have a definitive answer, so this is just some thoughts. Those with low attention span can say TLDR. Simple questions about weather can rarely be answered simply.Sadly, Frank, some of them,(( do but are doing it anyway. I have wondered, and maybe you can advise, how dependent is the ECMWF on data from the US?
Added a bit.Sadly, Frank, some of them do but are doing it anyway, because it's profitable to them. I have wondered, and maybe you can advise, how dependent is the ECMWF on data from the US?
This assumes GHGs can be reduced. From what I can tell every method of reducing CO2 will increase methane production. It’s not a popular view due to the profitability of things like tree planting, but the science seems pretty clear. As such I think it’s vital we keep funding research around this subject as the answers we currently have are extremely naive at best in a subject still very much in its infancy.some stage, we can only hope that reductions in GHGs comes quickly enough
I do not know about carbon capture and how that affects methane. Removal of CO2 by natural means, reforestation, does not increase methane. In the “natural” world, CH4 tracks CO2. That was seen in the Great Dying in S America following the arrival of the Spanish when natural reforestation occurred. Research at UCL showed that a reduction in CO2 led to a reduction in global temperatures. Of course, we had a vastly smaller global human population then. A major reforestation might not have the same effect.This assumes GHGs can be reduced. From what I can tell every method of reducing CO2 will increase methane production. It’s not a popular view due to the profitability of things like tree planting, but the science seems pretty clear. As such I think it’s vital we keep funding research around this subject as the answers we currently have are extremely naive at best in a subject still very much in its infancy.
I had to check my French dictionary as I would have expected deluge to be feminine. Wrong, yet againAdded a bit.
Après moi le deluge. Quite literally, in this case.
It's variously attributed to Louis XV and Madame de Pompadour, as an expression of indifference to what happens when they're gone.I had to check my French dictionary as I would have expected deluge to be feminine. Wrong, yet again![]()
Not so, unfortunately. Leaves and other debris that fall to the ground can often get eaten by bacteria which produce methane as a byproduct. The Amazon rainforest is a net producer of greenhouse gases for this reason and methane as I’m sure you know is many times worse than CO2. The blind belief that planting trees will fix this is part of the problem and will eventually come back to bite us. As I said, the field is in its infancy relatively speaking and research will help with understanding what it truly effective and what just looks effective.reforestation, does not increase methane
It is easy to make such arguments and easy to find counter arguments, all with ho numeracy. What you say sounds plausible. However,a counter would be that lower CO2 would lead to lower growth and, therefore, less vegetation being available to create CH4. We know, historically that CO2 and CH4 concentrations are highly correlated, see https://weather.mailasail.com/w/uploads/Franks-Weather/1000basco2ch4.pngNot so, unfortunately. Leaves and other debris that fall to the ground can often get eaten by bacteria which produce methane as a byproduct. The Amazon rainforest is a net producer of greenhouse gases for this reason and methane as I’m sure you know is many times worse than CO2. The blind belief that planting trees will fix this is part of the problem and will eventually come back to bite us. As I said, the field is in its infancy relatively speaking and research will help with understanding what it truly effective and what just looks effective.
This is the problem and the reason more funding is required. Right now there’s too much reliance on “obvious” truths even by very well educated people and until more research happens we won’t know for sure we’re doing the right thing.Whether what you say is correct or not, I do not know.
I said that I did not know the answer because I am not an expert in that field. My understanding is that experts in the field do see reforestation as being a tool for sequestering CO2. I used Google to ask, “Do climate models show that reforestation would be of significant help in reducing Greenhouse gases?” I got an AI reply. It said -This is the problem and the reason more funding is required. Right now there’s too much reliance on “obvious” truths even by very well educated people and until more research happens we won’t know for sure we’re doing the right thing.
Even the question of is there new coal being made or not seems unanswered with the newer research suggesting that evolution has ended that with the creation of bacteria that eat dead trees. The evidence seems to lean towards evolution eventually making global warming inevitable regardless of human actions which would be even more worrying.
Whether correct or not, it would seem we have an opportunity to find a way to combat methane as well as carbon, but as long as carbon dioxide remains a lucrative fetish that won’t happen.
Actually, quite a lot of research into "Blue" ecosystems such as seagrass and mangroves. I've reviewed and revised many proposals and papers regarding this, and they DO look at the various emissions and gas balances. And that's one small corner of the academic world. Of course, institutions based in coastal cities tend to favour such research, so my sample (Hong Kong) is a bit biased. As @lustyd says, you have to look at the overall ecosystem, not just one element, but the evidence I've seen is that such systems do sequestrate carbon, but the catch is WHEN IN GOOD HEALTH. Degraded or unbalanced ecosystems can be net emitters.The problem is that in many cases the experts are being paid well to say those things. Yes, obviously, planting a tree collects CO2 initially. Less obviously, the leaves and branches that fall off into muddy floors can be eaten by bacteria which produce methane. Same for seagrass which is currently being hailed as the wonder fix for climate change.
AI models reflect more common text, so yes they obviously say that. The only way to make them say useful things is to ground them with good sources, but since the research money is specifically around CO2 right now there are no good sources, or vanishingly few which have more advanced research.
Not sure why you keep implying I’m not reading the whole post.
Most of the research is done by university and government scientists. I have never been aware that either were paid particularly well. Obviously, rotting vegetation produces CH4. The lesson from the UCL/Leeds U study is clear and the only credible explanation I have seen of the LIA. But, rather than trust my own or your guesses, I have to note what the experts say. Remember that, for every 10 ppm increase in CO2 has led to a 0.1 degC increase in global temperatures.The problem is that in many cases the experts are being paid well to say those things. Yes, obviously, planting a tree collects CO2 initially. Less obviously, the leaves and branches that fall off into muddy floors can be eaten by bacteria which produce methane. Same for seagrass which is currently being hailed as the wonder fix for climate change.
You are showing the usual misunderstanding about funding and reasons for climate research. Most funding comes from national governments and international agencies. Who else would you trust to approach the problem objectively? Not the industry or its pet poodles such as happened during the tobacco dispute and as we are seeing now, particularly in the USA with the Heritage Foundation. There are others.AI models reflect more common text, so yes they obviously say that. The only way to make them say useful things is to ground them with good sources, but since the research money is specifically around CO2 right now there are no good sources, or vanishingly few which have more advanced research.
But coal was created prior to the bacteria that can eat the trees and make methane. There’s no new coal being made so that process can’t work as a cure here.After all, the coal and oil we've been burning to create the problem was laid down in environments where there was a net sequestration of carbon!
I’m not misunderstanding at all. If you think governments don’t have agendas then you’re incredibly naive. Governments fund research often because it creates business opportunities that their friends then get grants to fulfil. If you open your eyes and look at the whole system there’s a very clear bias and money trail. Right now CO2 is the focus and it’s being milked for all it’s worth and until that money dries up no funding will be used to disprove CO2 as the problem. To anyone with half a brain CO2 is obviously not the problem, yet here we are spending money on tree planting and seagrass. There’s still no tax on jet fuel though, so it’s clear that solving the problem isn’t the goal.You are showing the usual misunderstanding about funding and reasons for climate research. Most funding comes from national governments and international agencies. Who else would you trust to approach the problem objectively?
