burgundyben
If there was a major current leakage in the water in a marina, within what radius would boats be affected?
To answer the original question. The leakage current field would look a bit like this:
Thanks, very interesting, but it doesn't show distance. I guess the amount of current leaking and salinity are the two major factors, but I don't really know.
I did find last night that my engine anode bonding had failed. So I re-made all those connections. I got readings of 0.3 or 0.4 ohms on my meter between anode and shafts (hence engines, all in direct contact), P brackets and rudders, so all the main components.
My meter reads 0.3 ohms when you contact the probes, so I thing getting 0.3 or 0.4 is fine.
I have no current draw with battery banks off and no draw with them on but nothing switched on.
No current draw through the bilge pump wiring with the float switch down (and as you's expect with the float down there's no continuity)
So maybe having fixed the engine anode bonding I wont have a problem.
I found an earth leakage following Nigel Calder's advice. You are looking for really low level current flow.I did find last night that my engine anode bonding had failed. So I re-made all those connections. I got readings of 0.3 or 0.4 ohms on my meter between anode and shafts (hence engines, all in direct contact), P brackets and rudders, so all the main components.
Be sure all your bonding is quite independent of any wiring that carries current and that there is no way the bonding can carry any DC load current.
Thanks for taking the time to comment.
I'll go for a weekly swim under to visually check on things, if problems persist I'll invest in a silver chloride reference cell (albeit I'll have to work out how to use it and interpret the results).
Here's a pic of the prop nut, perfectly good nut to this in 2 months.
I think I'd want to find an underlying cause ...... I am sill thinking, despite all your checks, of an onboard defect or fault, causing electrolysis.
