Harpsden
As this engine is new to me I was systematically working my way around identifying all the main components, pipes etc to get to know the engine.
I found the lift pump nicely hidden behind a cooling plate but couldn't find any way of manually using it.
Looked at the documents for the engine on line and it seems the marine version is electric only and can only be operated by turning the key on at the ignition (but not starting the engine!) OR using a command from the engineers laptop when it is plugged in to the engine management system. In which case bleeding the engine at sea if you are by your self must be very difficult.
If anyone has experience of these engines have I got that right or am I missing something blindingly obvious (which is probably the case) ?
Many thanks
Harpsden
Many thanks
Harpsden
