CT115
Active Member
I have a Cummins engine it is a 4BT (A) M 150 hp @ 2800 rpm with a High Output (HO) rating.
The engine if fitted in a 13m Dutch steel displacement motor boat and is believed to have done about 1500 hours. We have owned the boat for two years and it has been serviced by a highly competent, but not Cummings trained, engineer
This year it has done 400 hours; 300 hours at around 1500rpm when used in inland waterways and the rest at between 2000 and 2200rpm.
A couple of months ago we finally traced an oil leak to the pipe used to remove oil from the sump.
This was cured by putting PFT tape round the sealing bolt in the end of the pipe.
We then removed the dip stick with the engine running and there is oil blowing out.
There is no leakage with the dip stick in place.
Should I be checking sump pressure and if so how. Is this likely to indicate piston ring wear?
Any advice greatly appreciated.
