dulls
N/A
My cruising chute (it was not a spinnaker anyway) was ok to about a close reach.That would surprise me, as the whole point of a cruising chute is stability. I've certainly never seen a cruising chute with any luff projection.
You've probably seen tones of them and called them asy's.That would surprise me, as the whole point of a cruising chute is stability. I've certainly never seen a cruising chute with any luff projection.
I think that many sail-makers use the terms "cruising chute" and "Asymmetric" completely interchangeably. I have what Jeckells usually called a cruising chute, and the luff is, if anything, curved outward. I have considered trying to set it using the spinnaker pole, but as the reason I got it was to avoid complexities of handling (I usually sail with just my inexperienced wife as crew), I haven't done it yet! I find that the sail sets fine with the wind almost dead aft, anyway.The principal difference between what sailmakers sell as an Asymmetric Spinnaker and what they sell as a cruising chute is in the luff. If you took both sails and laid them out on a lawn, then took some string and ran it from the head to the tack of both sails you would see that on the cruising chute the string would be outside the sail, so the luff is a bit hollow. On the Asymmetric kite the string would still be inside the sail, so the luff projects in front of the sail.
The result of this is that the cruising chute is, as you might expect, somewhat more stable but less powerful. The asymmetric kite will be a considerably more powerful sail, and as you've seen better able to sail lower than a cruising chute.
However, the drawback is that they are not "set and forget" sails when sailing low. A good crew on a J109 can sail as low as 170 degrees with their A2 asymmetric, but to do this takes very careful co-ordination between the kite trimmer and the driver, and the rest of the crew hiking hard to roll the boat to windward and help the sail rotate around the forestay. Like this
The best way to boost your downwind performance with a cruising chute is to pole out the tack of the sail.
Huh...You've probably seen tones of them and called them asy's.
Look at what Hyde call a cruising chute:
Buy Touring Gennaker | Yacht Accessories for Sale | Hyde Sails Ltd
The luff is clearly quite convex.
That has been my experience. We also had whisker poll and it was very useful on the chute.I think that many sail-makers use the terms "cruising chute" and "Asymmetric" completely interchangeably. I have what Jeckells usually called a cruising chute, and the luff is, if anything, curved outward. I have considered trying to set it using the spinnaker pole, but as the reason I got it was to avoid complexities of handling (I usually sail with just my inexperienced wife as crew), I haven't done it yet! I find that the sail sets fine with the wind almost dead aft, anyway.
I think people were calling things like that 'cruising chutes' before many racing yachts were using terms like 'A3'.Huh...
So my question then would be what makes that a cruising chute and not the A3 it looks like....?
I have spent some time trying to google the differences and i still feel confused about it. I think there are a few interchangeable words.I think people were calling things like that 'cruising chutes' before many racing yachts were using terms like 'A3'.
We had a pretty similar cruising chute last century.
I think the straight luffed cruising chute is the newer invention, but the point is, 'cruising chute' covers a fair range of shapes.
Some of which are much more versatile than others.
Also, what people consider the 'normal' size for a given boat is quite variable, so making blanket statements and comparisons is likely to be open to error.
My Dad's old Griffon had a cruising chute that was hollow luffed, and so did his next boat, so that's mid 1990s. As far as I was aware cruising chutes had straight or hollow luffs and weren't far off triangular in shape, and the A-sails that were developed out of skiffs etc were the first to add luff projection.I think people were calling things like that 'cruising chutes' before many racing yachts were using terms like 'A3'.
OK, but what about using a 'cruising chute'with a pole? Any reason why not?
If you do, what is it? A cc or a spinny?
And what about using a spinny (asymmetric or not) bolted down to the bow? Does that make it a cc then?
Is there any fundamental difference between the two other than shape - ie symetric and assymetric? Is the use (or non use) of a pole of any significance? ie you can use ot not use a pole with either at will?
I once did that to an old 505 kite. My Mum sewed it back together and it survived many more races.On a related subject. I hoisted our Asymetric Crusing shute in gusty conditions travelling back from west Cork yesterday. It lasted long enough to get a nice photo then split right across the sail !
Is it worth trying to repair ? Do these repairs last?
I purchased it second hand from Sail Exchange ( yes, I have seen the many threads on the site relating to JP and Sail Exchange). I'm wondering if the sail had degraded over time. Does this happen ? It looked ok but was it "rotten"- how would you tell?
I have the sail and snubber kit. I presume I can get a sail made and use my existing snubber kit? Whats the right weight fabric for a Crusing 37 foot boat sailed light handed .
Regards, Kinsale 373
A couple of years back we blew out a kite such that essentially all we put back into the bag was 3 corners connected by some tape and an assorted collection of cloth. Packed it off to the sailmakers without much hope, but it came back in good enough condition to still get used for races. More than good enough for cruising uses.On a related subject. I hoisted our Asymetric Crusing shute in gusty conditions travelling back from west Cork yesterday. It lasted long enough to get a nice photo then split right across the sail !
Lovely video. How do you post a video and did you reduce it in size?I can fly my Momentum ASpin from about 50° apparent all the way down to a dead run in light airs. It's got a definite convex luff and I trim it as I would a normal spinnaker easing until it starts to curl then sheet a bit and trim as the boat accelerates. Love it!
hosted on vimeo then used the insert media function which is in the dropdown next to the smilie icon.Lovely video. How do you post a video and did you reduce it in size?
