Cruising chute
Metalicmike
8 Apr 2023
Tenerife
I have spinnaker winches and have dedicated sheets hung on the guardrails. I use my spinnaker halyard to launch the sail with the foot attached to the bow, I also have a double block on the bow and run the line for the sock back to the cockpit onto another block tied to a rear cleat the line then runs back through the bow block to another block on the spinnaker halyard.. I have thought about adding a bowsprit to stop the chute fowling the Genoa however I have decided against this as it will effect up wind performance.
Paulfireblade
13 Mar 2020
Buckinghamshire
Did it make a significant difference with the main down?
Friends in a Moody 336 were catching us with their Spinnaker and Main sail up, once I dropped the main we were pretty much matching their speed so it did seem to help. Wind was only 4 - 6 knots.
My cruising chute doesn’t look as big as there Spinnaker so I wondered if there was more likelihood of it being in the shadow of the main.
Paulfireblade
13 Mar 2020
Buckinghamshire
Anything that can be done to speed up deployment is a must, I also run my sock line back to cockpit but use a triple block with a separate up & down. I leave the tack line and sock lines clipped to the pulpit ready and plan to start leaving sheets rigged and clipped to guardrails ready.
I did leave it still hoisted whilst snuffed but sadly wrapped around the Genoa so won’t do that again
B27
26 Jul 2023
If there's one thing that's more important than getting a kite up quickly, it's getting it up cleanly with minimum chances of a tangle.
I used to use a sock, which was great for having a minimum time of the kite not controlled , but this year I've just been launching the kite outside the genoa on a very broad reach.
Pre-set the sheet.
Halyard then tack line.
With extra hands, halyard and tack line together.
