superheat6k
No problem - this is part of my day job, though fortunately we mostly avoid single phase nowadays.That's great stuff and 100x better than my useless ramblings. I'm going to print it off because my brother has several of these very units and I have one similar. Btw, the compressor is a copeland (scroll) and they have data on their website too. I think you're right that there is no speed control on the motor. Anyway, many thanks superheat. This is a grand forum :encouragement:
With the scrolls it is vital you never run them backwards. Horrible tinny things, extensively developed NOT to be repairable by our industry. We did try to remanufacture them, but they are so cleverly put together and welded closed that the work to repair one exceeds the cost of new, and Copeland control about 90% of the market for smaller scrolls, sharing the larger end with Maneurop (Danfoss).
The field guide I put up yesterday was first written to provide field engineers a reference for wiring a single phase compressor. We used to get so many back with start up faults because the engineers just don't understand how single phase motors work. If you mix up the Start and Run terminals the start winding will burn out immediately.
Phase shift in electrical motors flys over most peoples heads, especially those dealing in the field with these tiny compressors.
Speed control is mostly done now with V/F Inverters, and many smaller AC splits and the like will have special motors matched to the maker's own inverter so they are impossible to fix. Jimmy's compressor is a simple rotary vane, and at 17,000 BTU/hr thats about 1.5 American Tons or 5 kW. The rule of thumb is 1 HP of compressor power required per American ton (12,000 BTUs/hr or 3.517 kW cooling capacity (not input energy)).
Copeland have introduced the digital scroll which uses a fast acting solenoid valve to pulse the discharge to provide capacity control, but the main control of capacity on the smaller systems is simply the fan and the thermostat that turns the compressor off when the unit reaches temperature.
No problem presently with R417A, but I expect it will become scarce in the next 5 years or so along with most other HFC refrigerants, R410A, R407C, R422D, etc, Even R134a will be mostly gone in 10 years time. Not sure what the answers will be for AC on boats, as most new gases will be flammable to one extent or another. Watch this space !
