simonfraser
I like the perceived extra retaining strength and security of the external nut and split pin.
Loctite the nut onto the pin.
But which is more secure ?
On a 4 part shackle there is a hole on the pin so once you have placed the nut onto it the hole is for an R clip or split pin for security
In the past I have used the green? rated shackles tightened up with a spanner and then wired up. Never had an issue with it coming undone. Wichard do a s/s shackle with a counter sunk head. There is more on Vyv Cox website about this.Tnx guys, it’s to connect chain to anchor.
Don’t care how tough it is to take apart, just want max peace of mind.
By the sounds of it loctite pin into nut and split pin is best.
Changing my anchor so just revisiting the connection, no i am not saying![]()
Bolted bow shackles do have some appeal for attaching the chain to the anchor.
They are in theory stronger with side loading. The nut and split pin is more secure than Loctite alone, and easier to remove quickly or even underwater.
