Doing it on board using the engineering facilities of an average cruising yacht, to a repeatable standard which you trust to hold you to anchor in heavy weather, seems almost insurmountable.
I have been carrying around a couple of 10mm Crosby chain joiners for years, without even trying because I don't have a big enough anvil or vice to hammer them on. (The actual hammer isn't so much of a problem).
Another point: If you went to the trouble of loading the chains to be joined in a vehicle, and had a friendly workshop to ket you use heavier facilities, what would be the ideal way to do it? Lots of light hammer blows? One very heavy blow?
How can you judge if it is done properly, the whole proceedure seems fraught with pitfalls, and unlikely to promote a good nights kip at anchor.
How about slowly squashing the pins in a huge press, until they spread into their holes? (This last sounds favourite to me, but I have no way of telling if it is correct or even safe.)
I did it one spring when in the boat yard - chain dropped to the ground and used a masonry lump hammer as a make shift anvil.
repeated heavy blows got the "pins" hammered flat with no play. As per my previous post, getting the chain into the link and the two halfs lined up ready to battered into shape was a right pig of a job.
Now it's done - I'm confident it is well strong enough to give me a good nights sleep - indeed I sat out a summer storm quite happily since.
Would I do again or just buy a whole new length of anchor chain...
Thanks, I did not realise that the peening over the pins did not contribute to the strength as you say.I've also done a couple of 10 mm Crosby links, in the yard the way scruff describes, and it was a straightforward job. The peening over of the pins is simply to stop the link coming apart, and (provided they are peened sufficiently to hold both halves securely together) does not contribute to the strength of the link. I've anchored quite happily on board that boat since doing so.
It may not contribute to the strength but if there is play there will be movement and if there is movement there will be wear. I don't have a windlass so I think it's going to be a pair of back to back shackles.Thanks, I did not realise that the peening over the pins did not contribute to the strength as you say.
