Maritimus
Hi Fran!
I was last couple of days on Boat show in Zagreb and reply is delayed.
We in Maritimus Consultant are not gridy. We have enough work and we don't need to cheat our customers as some other doing (remember "Customs certified court assessor" which must make valuation survey). Honest approach to the clients and knowledge in combination with hard work brought us on leading position in Adriatic area. On short run we loose bit of money but on long run we are the winners.
As any other respectable flag Croatian is requesting entry survey. Only FOC (flags of convenience) are registering all including non existing ships. Survey is mainly based to safety equipment and boat seaworthiness.
Each life raft have service period (1-2 years). Inspector will check that certificate is still valid same as for fire fighting extinguishers and pyrotechnics. It will be checked that boat have minimum required equipment which list will try copy/paste in another post.
There is clasiffications of sailing areas from 1-6. Sailing area in Croatian waters is 3. Bigger number, bigger sailing area , more equipment.
Third party liability insurance should be issued by insurance company which is registered in Croatia. It could be foreign but with legal branch office in Croatia (Alianz, Generali, Grawe, Basler.. are present in Croatia).
I should warn forum members about one more danger. Realized that some companies which are offering boat import are not existing. Hard to beleive but it is fact. I will not list them but check if your consultant/agent have active company. Below is link to Court Register of all companies in Croatia. Enter just name in place after "Ime/naziv" (Name) and press bottom "Pretraži". If your agent is listed below column "Status" as "Aktivan" (Active) it is good sign. You are free to try with Maritimus Consultant
. You can check balance sheet but this is bit more complicated.
https://sudreg.pravosudje.hr/registar/f?p=150:1:4003487390594918:::::
Regards Sinisa
www.maritimus-consultant.hr
maritimus.consultant@st.t-com.hr
Regards Sinisa
