Crinan Canal Water Restrictions.... again
ctva
8 Apr 2007
Email update from Scottish Canals just now, not looking good for the season... :rolleyes:
Water Conservation.
We experienced an unusually dry 2024/2025 winter and therefore our water resource is restricted. One of our water-saving measures is to restrict low-tide lock-ins around the monthly springtide. We will not lock boats in/out at the sea locks around the low-water cusp. When applicable, please contact the sea lock for the timings.
A single Lock-in restriction also applies.
To further support water conservation there will be no single boat lock ins. Where a single craft splits from a group, that vessel may also be held for a period to join another lock-in. Expect boats to be grouped together in locks to reduce the amount of water used and to help us maintain service throughout the season. Therefore, we suggest you call the sea lock in advance to book a time of exit or entrance. The sea lock operator will then attempt to pair you up with other boats on the booking system.
Physical lock restrictions at Lock 15.
Due to construction at the lock, only one side of the lock is accessible to shore-side operatives. Only the lighthouse side is accessible. This means on entering the canal, you have to tie up on port side, and on exiting, on starboard side.
New Hours.
Note that our operatives now take a lunch break between13:00 and 13:30 and won’t be manning the Sealock or operating locks or bridges. We will endeavour not to cause undue delay and hope that your co-operation will help us maintain levels of service throughout the summer period. Our operatives will still do their best to make your onward journey as speedy as possible.
Rivers were swollen again yesterday in Argyll and Bute, so hopefully the water in the loch. and canal will have been topped up.
That does not reconcile with friends and family in Fort William, nor my experience in Cornwall this winter. A dreich winter was had by all. Including three named storms in succession.
Did they not put the plug in after working on the canal?
I wonder if they look at water levels in Scottish lochs?
@Sandy A couple of years ago, the canal was drained in sections to replace a few of the gates. At that time the plugs were modified so that the plug gates could be lifted from surface by operation of a screw type device. The banks of the canal leak, apparently significantly so, and this was mentioned at one of the public consultations. SC responded that they were not addressing the bank leaks. Very likely the leaky banks and lock walls (in some locks) are still draining off water to the surrounding land all year round.
February and March have been very dry in Scotland. All changing again as the season starts, but definitely been exceptionally dry and sunny 6 weeks or so up here.
Have they actually got a booking system that works now? I’ve booked in in the past on the website and called the sea lock on my way to confirm a more specific arrival time and been met with surprise and then still had to wait for considerable time to actually get in. I’ve been in the basin at crinan overnight, spoken to staff the night before and agreed I want to leave as early as possible in the morning - then speak to the gate staff first thing, oh we didn’t know, we’ve a boat coming in at 0930 so you’ll have to wait till after that!
I’ve not objection to them having lunch, and staff protecting their lunch - but I have found that those times can be a little bit religiously protected, and that means if the lock has a 25 minute “cycle” they stop moving boats 25 minutes before lunch so nobody is stuck in a lock over lunch…
Things may of course have improved.
I find the paragraph on lock 15 puzzling. Lock 15 is the sealock at Crinan. As you enter from the sea the port side is where the lighthouse is and they say in the paragraph that that is the only side they can access. But their office is on the other side!
It has been quite a few years since I was through the canal so I realise that the controls for the hydraulic gates and sluices may be on only one side and that may be the lighthouse side but it stretches the imagination to believe that they can't access the side on which their howff is built.
Bodach, I think it’s temporary works on the top of the lock nearest the office. The hydraulic controls are that side but set slightly towards the basin. I recall reading a proposal to rebuild a wall outside the canal office and I think resurface the top of the lock - so I think it’s a temporary limitation at being able to tie up that side whilst the work is completed.
Thanks ylop. Like others, I also wonder about this " dry spell". The inland loch near our house has been above normal level for most of the winter and last Saturday the footpath in front of the car park was under water.
