Quandary
I have been told that from tomorrow the sea locks will be restricted in operation to two hours either side of half tide, not surprising , the reservoirs must be very close to empty.
Not just that but they bought a freshwater pump and the wrong strainers apparently too.The pumps were only used fora couple of years, you can,t mix salty water with fresh in these times, think of the confusion for the poor wee fish.
You've intrigued me enough to do a wee sum ...AND you'd think there was a massive difference in HW / LW so saving lots of water, we're at neaps so for the next week or so the tidal range is averaging LESS THAN a meter. That is miniscule in the amount being saved.
I've seen Carp and Mullet swimming side by side in Bilbao. They didn't seem to mind the mix.you can,t mix salty water with fresh in these times, think of the confusion for the poor wee fish.
Go on, put that post on the Crinan Canal FB post...You've intrigued me enough to do a wee sum ...
Suppose the area of the locks is AL, the area of the basin is AB and the height through which the sealock level falls is h. That means that the volume of water used in a locking is AL x h, and if all that comes from the basin the consequent fall in basin level is AL x h / AB.
Now, do this again for Lock 14. Lock area AL, drop d, reach area AR, and the drop in the reach level for the locking down into the basin is AL x d / AR.
The drop d in Lock 14 is some base value D plus the drop in the basin, do d = D + AL x h / AB which means that the drop in the reach is
(AL/AR) * x [D + (AL/AB) x h] which means that for a unit change in h, the drop in the reach level is AL^2/(AB x AR).
So all we need to know is the area of a lock (28m x 6m = 168 m^2), the area of Crinan Basin (estimate room for ten puffers, so 1680 m^2) and the western reach (4km x 10m = 40000 m^2) and the ratio above is 0.00042.
In other words, for every drop in sea level at Crinan sea lock of 1m, I reckon a locking out of the canal drops the western reach level by an extra half a millimetre. How perturbing.
Fair point.No need for anything so complex. Close the sea lock, and the leaks will have it filled within the hour, ready for the next customer
Do tell.I had the misfortune of coming through today west to east. Utter chaos ...
And you never said hello. As JD said, do tell.I had the misfortune of coming through today west to east. Utter chaos, a brilliant effort by the lock keepers especially Douglas at Crinan sea lock. Round the Mull for me next time me thinks.
Pump into a tank to lower, then drain it back to fill and top up losses from the basin; that or the canal will cease to have any purpose if this carries on. The sealock is always going to be fluctuating from brackish to full briny anyway.The pumps were only used fora couple of years, you can,t mix salty water with fresh in these times, think of the confusion for the poor wee fish.
... the canal will cease to have any purpose if this carries on. ...
