penfold
Madness. I doubt SC employ enough staff to do that, it was certainly DIY the last time I went through.
The bridges and sea-locks can't be DIY. Accompanied passage by staff might need fewer of them...Madness. I doubt SC employ enough staff to do that, it was certainly DIY the last time I went through.
The staff seemed overworked but insisted that they do the locks (and had the winding handles). I do not know if permanent licence holders might be treated differently.The bridges and sea-locks can't be DIY. Accompanied passage by staff might need fewer of them...
When I worked there, last century, the place was teeming with staff - so if a yottie did something daft and ended up "running water" somebody was generally close at hand to sort it. If they now have much reduced staffing levels one can understand why yotties now don't get to touch the sluices. Are permanent licence holders to be trusted?The staff seemed overworked but insisted that they do the locks (and had the winding handles). I do not know if permanent licence holders might be treated differently.
What precisely is wrong with ropes with bowlines on ends, tailed at the boat? Worked for us through plenty of passages through Crinan, Caledonian and across Sweden via Gota and Trolhatte.………..
I have taken yachts and boats through quite a few canals and ship canals and deep sea locks such as Bristol. Crinan seemed the least prepared such that folk onshore are needed even on lockingdown as staff insist on bowline on bollard instead of running loop back to the craft.
You're doing it wrong Alan! You need someone on the bow holding both parts of a line round a hook or nail but NOT a cleat on the boat; the same at the stern; with you, the skipper, standing at the wheel shouting conflicting commands and, most importantly, the smallest, weakest member of the crew ashore to operate the gates and sluices. It seems to be the way most large AWBs do it so it must be right!What precisely is wrong with ropes with bowlines on ends, tailed at the boat? Worked for us through plenty of passages through Crinan, Caledonian and across Sweden via Gota and Trolhatte.
Bow rope taken back from bow cleat to genoa winch, stern rope on a second winch and easily managed by one person.
Easy flick gets bowline off the hook even from the bottom of the lock
Well yes, but aside from that it was all DIY and works well as long as at least one boat out of 4 knows what's what. Otherwise it's the blind leading the blind.The bridges and sea-locks can't be DIY. Accompanied passage by staff might need fewer of them...
Flicking a rope of a hook high above ones head is chancy. Certainly would not work for Bristol channel sea locks which can be 14m (now have pontoons inside portishead lock but did not have originally ). I agree Crinan is small drop but still looping back to boat is fairly standard mooring and the risk of rope jam is less than bowline failing to get clear or snagging on lock wall.What precisely is wrong with ropes with bowlines on ends, tailed at the boat? Worked for us through plenty of passages through Crinan, Caledonian and across Sweden via Gota and Trolhatte.
Each to their own, but IMHO running ropes through a hook and back to boat is much MORE likely to jam in old stonework, where often gaps that rope under tension can get caught in, than bowline on ends ( which is " fairly standard practice"). And if you cannot do the easy rope flick off, surely not a problem as always needs to be somebody ashore anyway to close gates and sluices.Flicking a rope of a hook high above ones head is chancy. Certainly would not work for Bristol channel sea locks which can be 14m (now have pontoons inside portishead lock but did not have originally ). I agree Crinan is small drop but still looping back to boat is fairly standard mooring and the risk of rope jam is less than bowline failing to get clear or snagging on lock wall.
I happened to be at Crinan today so spoke to the Crinan Sealock staff. The suggestion that DIY operation of intermediate locks (ie other than the sealocks and first lock at Crinan) is no longer allowed is apparently not true. Still possible to do the locks yourself if you want, but they seemed to be very well staffed and so generally trying to assist boats wherever possible.No self operation of locks nowadays, and they seem to generally have two attendants at each lock, so it might just be possible to do it single handed though clearly not so convenient but I think from what I could see someone else going otherway this June seemed to be on their own. Suggest you speak to the Crinan office
