bastonjock
If you use a ratchet crimper and it gets stuck,there is a small release lever inside the handle.
Ive crimped the odd cable in my life,ive done all sorts of special ends for hazardous enviroments,for my boat,i would use the ratchet crimpers and the tinned copper type that you buy at RS componnents or maplins,you can also get these at Halfords.
For making the ends off,i would crimp the end of the cable,then dab a bit of epoxy onto the crimped area and then heat shrink it off,this is a cheaper option. This done properly will inhibit the ingress of damp into the cable end
The crimps in the UK come in 3 colours for crimps up to 6mm cable,yellow for 4-6mil,blue for 2.5mil and red covers 1-1.5 mill
if you have to go above 6mm it can get expensive as the crimpers cost a lot more and so do the crimps
