pagoda
In general they are not supported for use on small diameter hoses because the worm drive can easily jump and lose grip giving a poor seal. This is because on the small diameter clips only one or two teeth are engaging compared to the larger diameters where many teeth engage. Brands like Jubilee are better quality and this is not an issue. There have been cases where the clip does grip but is then overtightened significantly, just in case it jumps, and then the hose is crushed. This causes an increased probability that the hose will tear at the interface between the clamped and unclamped part. That is what was explained to me, many moons ago. I think though that low quality clips and insufficient clamping pressure is the primary reason.
fIne, almost agreed. At 25 to 35 mBar -downstream of regulator, exactly how much clamping pressure is needed for a decent seal? Securing of the hose and of the bottle strike me as rather more important than worrying about crimps compared with worm drive clips. And less so if you replace the hoses every 3 years?
