Cranking amps (CCA)
Rum_Pirate
23 Aug 2004
A tiny Island, Caribbean
The battery requirements are detailed in the owners manual
In this case for a Yamaha 9.9 electric start 4 stroke max CCA is 245 -433.
Googled "what happens the maximum CCA rating is exceeded" and could not see a single reason against using a higher CCA battery.
So why is there a NOTICE : 'Do not use a battery which exceeds the maximum CCA rating' ?
ylop
10 Oct 2016
I guess theoretically a battery with greater amps could make things worse if there was a fault - but I think you are worrying about nothing. You could always add a massive 400A fuse and then the battery would not be able to supply more that the spec.
Rum_Pirate
23 Aug 2004
OK update I managed to call Yamaha Corp in the USA.
A lady there, Pam, was helpful.
Advice received:
No damage will occur but I would be unnecessarily spending money I didn't have to if i purchased/used a battery with greater cranking amps than recommended.
In my case (gave her the serial number) the recommended CCA is 323 -520 CCA.
So now you know. ?
Tranona
10 Nov 2007
That is not necessarily true as you will find out when you look at specs against price.
However, the demands of the starter are modest and as several said on your other thread a basic car battery of 45-70Ah capacity will do the job. only need the larger if you have domestic demands or instruments and limited charging. You will need to supplement your charging in addition to the alternator with solar or mains charging.
jamie N
20 Dec 2012
Fortrose
The starter is requiring a Voltage and amps to energise it. Having massive CCA will only cause damage by continual operation of the starter on a 'dead' engine by an idiot owner.
Having 'available' CCA at the right VDC, has never destroyed anything.
jamie N
20 Dec 2012
Fortrose
The analogy is similar to having a very large petrol tank on a small car; the car won't run any differently providing that you adhere to the service schedules; i.e don't crank the engine for over 30 seconds or whatever the manual states.
RTFM.
Refueler
13 Sep 2008
Far away from hooray henrys
Why ????
Starter motor demands volts / amps as determined by the work it has to do to turn over the engine ... the demand does not change based on battery used unless battery cannot supply the demand ... then starter does not get full demand.... in fact it would likely cause battery damage.
You could have 1000A CCA capable battery and starter will still only draw the amps it needs ....
jamie N
20 Dec 2012
Fortrose
Why ????
If the CCA is too low, then the engine won't turn over for very long. If the CCA is very high, and the owner's a 1/2 wit, there's a danger of the fool turning over a non-running motor for a long period of time, potentially burning out the starter, or screwing up the ring gear; whatever.
Having a huge CCA isn't the problem, nor did I intimate that it was, so I believe that you've misread my posts 6 & 8?
Refueler
13 Sep 2008
Misread ???
How can that be misread ??
noelex
2 Jul 2005
Advice received:
So now you know. ?
One general consideration is the IC (interrupt capacity) rating of any fuse protection incorporated into the design. A battery with a larger CCA rating requires fuses (or circuit breakers) that have a higher IC rating. I have no idea if this applies to the Yamaha, or if the outboard even has any circuit protection, but it does explain why a manufacturer may sensibly limit the maximum permitted battery size in some cases.
Bigger is not always better :).
If the the advice from Pam was correct, this concern obviously does not apply in this case.
