Cracked exhaust riser
Steve_N
31 May 2004
Fife
I've just found out why I've never quite managed to completely stop a rusty weep where the exhaust hose fits onto the elbow!
Just out of interest, how might this have happened - is that likely to have been a flaw in the casting perhaps?
Cast iron risers are notorious for failing simply due to old age.
Constant expansion and contraction with bit of added corrosion.
Have had risers crumble on both Volvo Penta and Mercruiser engines.Probably require renewal after 5 years or so.
Just goes with the territory...................
It is rather a design flaw. Volvo Penta should know better that you cannot mix cast iron and salt water and expect durability. If you are lucky find an after market stainless steel replacement. Or have it made for you. The original replacement is a waste of money.
My old boat had a 24 year old Volvo Penta 2003T, with the original cast iron exhaust elbow still fine after 2300 hours. I don't think that one could reasonably expect much more.
Stainless also has a problem with hot sea water. I have welded up both my stainless steel exhaust elbow and water cooled manifold.
This is not problem to me as I have stainless welding equipment at home.
It is slightly less clear on a Volvo manifold than on a Yanmar but I believe the cause of cracks in the latter to be thermal fatigue. This is not the result of repeatedly heating and cooling something, but the repeated change in stress levels due to differential thermal expansion in something that has various thicknesses, definitely the case with the Yanmar ones. Fatigue is rather more difficult to imagine with the Volvo one in the photo, partly because it does not have such pronounced section changes but also because the text books state that fatigue is not a problem in cast irons as the crack growth is always arrested by the graphite. However, I know this to be untrue having investigated the failure of cylinder liners in locomotives. Except in very special cases corrosion does not cause cracks, which almost certainly rules it out.
Interesting, thanks.
I'd often wondered how the builder had managed to get the exhaust hose onto the tail of the elbow because there was such an increase in diameter visible at that point and the hose is wire-reinforced. It was only when I cut the hose away with a saw that I realised that the tail had swelled and spalled with corrosion and expanded inside the hose - the crack wasn't visible until I chipped away fully 5mm of rotten cast iron all the way around to get down to the remaining 'good' iron, but even this is fairly porous. Perhaps it was that pressure that did for it. It is the original though so has lasted 32 years.
Once the engine comes out I'd hoped that someone might get some use out of what is still a good unit but sadly this now changes the economics of that situation somewhat.
