Daydream believer
Of course, I will be here to help when I can. But you will have to learn to take responsibility for your own actions eventually.I don't need to - I can rely on you to add the correction.![]()
Just a thoughtI need to do this before I sell the boat, but the mast is definitely coming down to do it. The mast will stay down until she's sold.
Yes, preventing that is a bit suspicious, my reaction too...Just a thought
I'd expect to be able to make a test sail, check the sails and mast electrics before I bought a yacht......?
Jonathan
Depends on the investment & the overall state of the boatJust a thought
Jonathan
I would be happy to see the mast on the ground & examine it there for any defects. Place a battery on the wires to check the nav lights. Take a chance on VHF & wind instruments. Sails can be rolled out & better checked for damage etc on the floor. One knows that with a second hand boat they are more likely to be knackered. I would be looking at the rudder & keel when on the hard. If I was buying, then I would want it antifouled before the launch.; whether I did that myself or not.
As for sailing the boat- surely if one is buying a particular model one would have researched how it sailed anyway. One knows that cheapo bilge keel oldies are not going to sail well. Bit different with newer models where one is spending lots of money. But then there will be some info somewhere. There will be people to ask.
But If one is spending say £30K+then £1000 lifting in & out of the water is not so great in the grand scheme of things.
I guess I won't be seeing you thenTo me, if the yacht is not available in the water with its mast rigged, I'd walk. There is plenty of choice. I'd also expect to be able for me, or better, my surveyor to examine the yacht out of the water.
A lot of second hand, not third and 6th hand, yachts have sails that are hardly used. but I would not rely on it - and I'd prefer to see the sails in action.
If its a bilge keel and the tides correct - I'd be more than happy if the yacht is made available 'dried out'.
There are lots of yachts for sail - sadly the owner will need to make an effort, for me.
If the yacht is badly fouled - again - I'd walk - unless I was buying a project yacht and then my offer would reflect my doubts. Its upto the owner - if he wants to sell the yacht must be presentable.
Jonathan
There is more to a test sail than .... the test sailI guess I won't be seeing you then![]()
That’s the approach I took. Now on its 5th or 6th season of faultless operation.I did it the easy way when our Stowe packed up. Left the old wire in the mast and fitted a NASA wireless wind which took around half an hour up the mast and a couple of hours modifying the instrument panel and fitting the display.
IMHO when your battery dies and you’re mid ocean you may change your mind about the simplicity and reliability of a wire.IMO - it’s 2024. Absolutely no need to run wires down the mast for a sensor.
Somehow, if I was going on a long ocean voyage, changing the battery might be on the "to do" list before I left.IMHO when your battery dies and you’re mid ocean you may change your mind about the simplicity and reliability of a wire.
The solar option has a battery, and those batteries often cause issues. Wires tend to be simpler and more reliable, there's no pairing, no firmware, no interference, no battery, not a lot to go wrong aside from physical damage.I might well have gone for the wire or solar, option anyway
If we’re on an ocean passage and the battery dies it might be a problem that ends in not knowing the exact wind speed…Somehow, if I was going on a long ocean voyage, changing the battery might be on the "to do" list before I left.![]()
But there again, I might well have gone for the wire or solar, option anyway.![]()
Knowing wind direction might be more crucial than speed. So you might have to resort to the proverbial wet finger to gauge that...If we’re on an ocean passage and the battery dies it might be a problem that ends in not knowing the exact wind speed…
I’ll classify that on my internal risk register as “acceptable”![]()
Or the ubiquitous windex at the top of the mast??Knowing wind direction might be more crucial than speed. So you might have to resort to the proverbial wet finger to gauge that...
Oh, do people have a windex as well as an electronic wind detector? We were considering how to cope with the latter having an outage...Or the ubiquitous windex at the top of the mast??
Aah old tech, wind vane?Oh, do people have a windex as well as an electronic wind detector? We were considering how to cope with the latter having an outage...
Of course if you want your autopilot to steer by the wind a windex is not going to cut it!
I'm sure we can all agree it was an advance on the wet finger, anyway...Aah old tech, wind vane?
