rafiki_
Great result Trevor, coming on a real treat.
Erm - probably not a good idea to look inside the cabin presently !!!Great result Trevor, coming on a real treat.
then scrub gently with a stiff hand brush along the grain
TCM wrote up about scrubbing teak decks on here years ago.
TCM was all for a sorta swooshiness with an unscratchy, moppy thing but otherwise broadly as per superheat. For regular cleaning I always tried to avoid any abrasion, letting the chemicals (principally oxalic acid) do the work with lots of water.
Did also sand on occasion, but - again 9mm teak - wouldn't dare touch 3mm with a machine sander.
But he did write it up brilliantly.
The brush I used was a soft domestic hand brush, and it was simply to agitate the first part cleaner into the grain, and brushing across would not have worked on a deck so dirty. After the initial rinse I used a soft deck scrubber just to spread the neutraliser around. What came off was a black slurry not wood flakes or splinters. The effort required was not too bad considering the area I had to cover (approx 10sq metres).Controversial Trev.
I was taught to clean teak decks with a sponge not a brush, unless really bad, in which case scrubbing should be across the grain, this tends to remove the higher wood grain and keep it flat. Scrubbing along the grain takes out the soft wood between the winter growth hence should be across. I guess it depends on whether the teak is qtr sawn or not, if not then anything goes. My new boat has a new teak deck, 9mm thick, qtr sawn, not sure of my plans to keep it clean yet.
I could say you are splitting hairsSo: it was soft and yet somehow stiff.
More Old Man Syndrome perhaps?![]()
Its been a while since I updated my slow but steady progress with Boadicea.
However, today I achieved a milestone on my galley refurbishment. The teak edge trim and teak shelf above the worktop and just below the window are still being varnished, so will be a couple of weeks yet before it is fully finished.
This is the second boat I have used Corian imitation worktop, Apollo Magna on, and I love the stuff. Not bad for £86 per 3m sheet, I have enough left over to sort the work surface in the fwd heads.
I am thinking about router cutting some drainer grooves to the right side of the sink, but I am worried I will mess it all up.
