Corded kill switch for a Seagull
Don't understand why you would bother doing this. The seagull design is that you set the idle speed at about 1/4 throttle - so that to cut the engine you just push the throttle back all the way. And bingo, the engine cuts straight away. What could be simpler? Not much to go wrong with that either.
I think the OP was think of a safety lanyard type of kill switch, not merely a stop button.
Anyway if you really get to grips with the throttle adjustment you can set it up so that it idles at minimum throttle control setting but stops when you lower the tiller.
Ah, yes, sorry - I missed that point.
But to make a seagull "safe" you need to cover the flywheel (or buy a late one). Other hazards include thin alloy exhaust - ouch if you touch it.
Yes, that is my intention.
Indeed - but was it an intended feature or an accidental consequence of the design, I have wondered?
