wully1
The stainless steel pistons on the ends of my whisker pole fur up and jam with white, crumbly paste. I’ve stripped and cleaned the piston pins, springs and the holes they slide in.
I have some of the insulating paste used to mount stainless steel fittings which will be too thick to use for this - or some copper grease which will work.
The question is - will the copper grease make the corrosion worse or is it safe to use?
