rolfbudd
Has anyone got any view on Copper Coat antifoul? Also how many rollers etc did you go through. Would like to do it our selves to try and save some cash so this will be our first time and so not sure on how much stuff we need.
But it is too cold in the UK at the moment - wait until the spring. You need at least 3 dry days, as well - or be under cover.
Duh!AP: it's hugely reassuring to learn that someone as smart as you can have senior moments as bad as mine
OP: "we are on Aegina, Greece at the mo so temps are still in the 20's"
We've done both our boats with Coppercoat. I highly suggest that you dilute the CC with (whatever is the recommended additive) to the full 20% allowed by CC themselves. Call CC if you cannot find the exact statement online. Ensure the coats are THIN!!! I applied 4 coats to past boat and had some runs. Did 5 coats fully diluted on present boat and it is much better.
GL
AFAIR, and I did it last year, it is only 10%. But fully agree you need to thin it as much as permissible; AMC will certainly advise this if you ask them.
I also agree. But eqqually, as per my remarks in post #7, don't chuck all the thinners in a mix in one hit. With a typical application (one person rolling) it will thicken in the pot during each pot's life. So hold a little of the thinners back to compensate.
We had two people rolling and one mixing; we didn't have a problem with it thickening in the pot. From my experience, I'd suggest that two people rolling is ideal on a 31 foot boat; by the time we had done one coat, it was time to start the next. I'd have thought that one person rolling would mean that it had gone off a little more than ideal before you got to the next coat. But the ideal is certainly to apply all that AMC provide in as many coats as possible!
I have applied Coppercoat on a very old wooden yacht.
Explanation :
The boat been build 1946, a sort of Bawley yacht. Total rebuild 1970, sheeted in fibreglass on new wood. In fact two hulls in one, hence the 8 tons for 8 meter length....
....BTW. Rollers. Since our under water hull is not smooth we had to use small ( 1” diameter, about 4 inches long ) rollers. More but easier work. As Gwylan said, do not spare on rollers.
Having applied it and removed it., I think copper coat is an absolute waste of time and money, but seems to work for some...
