Doug_Stormforce
Im looking to copper coat a competitive racer cruiser instead of anti foul. I am told copper coat is fast but don't see other race boats with it. Anyone with first hand experience?
If applied correctly to a smooth hull it will have a smooth finish as it is applied in very thin coats wet on wet. It could be burnish once cured. Have seen a very smooth finish on one boat I was thinking of buying.
My self-applied finish is not so smooth, but that's due to the "orange peel" finish of the underlying high build epoxy, not the Copper Coat.
Have been told that coating older boats can be a problem, all depends on the hull moisture content.
Just a small matter - the "orange peel" effect may be actually more hydrodynamically efficient than a smooth surface. However, I am not an expert on hydrodynamics! But I do know that smooth is not necessarily the best; look at sharks' skin, for example, where the decidedly rough denticles give the shark a hydrodynamic advantage; to do with vortex shedding, I think.
Many years ago I had the opportunity to ask a professor who really knew about the subject exactly the same question. He agreed that certain textured surfaces were more efficient than perfectly smooth ones. Water tends to remain attached to the textured surface so that flow induces friction between water and water, whereas with a smooth hull it is between hull and water, a higher figure.
I they're serious, big-budget race boats, none at all. Why bother when they're hardly ever in the water? (And if you wondered what those winch oxen did when not sailing, it's often polishing the bum. I might add the thought that such polishing was effectively free and probably did no harm, so why not?)I think the question i really should be asking is what race boats are using it? And if none why?
. Laminar flow is the general phenomenon, but that's as far as my understanding goes. Considering the budgets involved, someone out there must know an awful lot more.
Oyster use copper coat on their racing boats
http://coppercoat.com/coppercoat-info/antifouling-performance
Neosil is a silicone based hard system that looks like gloss paint. The silicone means that (apparently) nothing can adhere to it.
Coppercoat is not great for the environment and there has been some problems with application - often blamed on prepping the hull I believe.
