AdeOlly
Interesting thread this. Guess what, the port engine on my Prestige 34 has also been running hot!! Not overheating hot but at 91C with starboard only at 85C or a bit less. Temp stays at that from 2800-3400 rpm. It's erratic though, some trips it's fine some not. Last time out it was running hot to the anchorage. After I took a dip and cleaned the lower leg water inlets with a stiff brush the run home was at normal temps. I would not be surprised to see the problem again next time out. I have a suspicion though that the gauge could be playing up as I have seen it flick a few times and I also plan to change the thermostats if I can't find a gauge problem.
However I have KAD300s not D4s so my ramblings probably not that relevant. A bit of a coincidence though...
