Aydena
Active Member
I have a 3.0 Essex V6 which has been marinised, i however bought it with all the pipework in a big bundle and not conected to the engine, it is indirectly cooled and has a heat exchanger. I will get some pictures tomorrow to help describe what im trying to ask
My problem is i have a rough idea of where some of the pipework goes, im guessing where a radiator would normally be if it were a car engine that is where the heat exchanger connects ? I have a medium size bore pipe that runs from the back of the engines waterpump, i first though this went to the manifolds but then i though if i did that, then the coolant would just get ejected out the exhaust ? so any thoughts where the pipe may go ? With regards to the manifold shosn in the picture below it has 2 blue pipes which run across them, there is also a 3rd fitting on each manifold ? would this be for the "used" raw water ? I was thinking of finding out tomorrow with a hosepipe and see where the water ends up !
Secondly the engine has an oil cooler which sits behind the oil filter, how do i go about connecting this to the cooling system, does it connect to the raw water system ?
I know they are some vague questions but i assure you i will back it up with some pictures tomorrow
/forums/images/graemlins/laugh.gif
Regards
Regards
