chal
I know there are some other threads about this and have checked them, but apologies for any duplication.
Last time I used the boat, the cooling water intake got blocked. I only noticed this when I saw smoke (or maybe just steam, it seemed more like the latter as it disappeared fairly quickly) coming out of the exhaust. No alarm went off. We hadn't been out for long so I assumed the engine hadn't overheated and, as we were pretty close to home, we just headed back. That was a few weeks ago and since then I've been away and haven't had a chance to look at anything. Just done an engine check now and the coolant level in the heat exchanger is pretty low. I don't have any anti-freeze with me so I don't want to fill it to the top but I put maybe half a litre of water in and it didn't fill it enough for the level to be visible. Is it reasonable to assume it has largely boiled out or should I be looking for leaks? The engine is a Volvo MD2020. It's about 20 years old I think but seems in good condition and has been little used. This is my first season of owning the boat and I had the engine professionally serviced in April. No problems reported and it's run without issue since, with the coolant never needing any topping up at all. If there is likely to be a leak, is there any obvious place I should look for it? Many thanks!
Edit: I have checked the bilge and the water in it had a distinctly green tinge so it looks like, one way or another, that's where the coolant ended up.
