Coolant Drain Taps
Dino
27 Apr 2009
Ireland
Hi, I need to replace the coolant in my twin Perkins Sabre M265Ti’s. There are three drain plugs that all have their issues with catching the old coolant. One drains straight down on the Starter Motor.
Is it possible to fit Coolant Drain Taps to these engines? It would make future coolant changes a lot simpler.
burgundyben
28 Nov 2002
Niton Radio
@ChromeDone - very clean engine!
On my 265's I found the little BSP plugs in the HE's were brass and had dezinced and crumbled. Worth checking.
Greg2
24 Jun 2002
We have the same engines and I have a very good wet vac that I simply hold near to each of the plugs as I remove them. It sucks the water up as it comes out and makes an otherwise tricky job very easy.
My, perhaps unfounded, concern about fitting taps would be a failure whilst the engine is running resulting in loss of coolant and overheating.
Dino
27 Apr 2009
Ireland
That’s a great idea Greg, thanks for the tip. I’ll give that a go.
I also had concerns about fitting a valve in case it was accidentally opened and lost coolant.
Greg2
24 Jun 2002
It is very powerful so it gets most of the coolant and any that goes into the bilge is easily sucked up!
ChromeDome
25 Sep 2020
After having them on 2 cars for 5 years (oil) and 2 boat engines for 12 years (coolant), I'm confident they won't leak.
On the cars, the biggest fear was if something hit them, but nothing ever happened.
