cool box insulation
robmcg
17 Sep 2006
In exile in Scotland
Time to revisit refrigerating our galley coolbox. For various reasons, I need to find some insulation that is flexible so can be stuck on the inside of the box. Decent thermal capacity needed. I know this isn't the optimum solution but I can't take the galley apart and space is limited. Anyone solved a similar issue?
CJ13
10 Jan 2008
We've insulated the inside of our cool box ( ours is a fridge ) with 50mm 'Blue Board' rigid insulation, recommended of Nigel Calder, topped with a layer of 'Thermowrap' which looks like foil faced bubble wrap. We use double sided tape to fix both so that it can be removed for cleaning / replacing. Make a huge difference.
Blue Board is available from SIG and Thermowrap from B&Q or any DIY store.
We do take great care not to allow anything smelly (milk etc) to leak & generally change the Thermowrap each season. The Blue Board has very low absorbtion of moisture so just wipes clean.
John
robmcg
17 Sep 2006
John
Sounds doable, who are Sig?
Rob
