jeremyshaw
Over the years I've had a few hair raising and expensive moments with gear or throttle cables failing. Of course it always happens at the worst time - when you are approaching a dock or swinging close to another boat.
And no, our cable runs are not excessively tight bends - all to correct spec.
I looked at changing to an electronic/hydraulic system but they are very pricey and a lot of work to fit. And then I met the skipper of a 100' yacht whose system had just developed an intermittent fault...
Some mechanics say "change them every couple of years" Others say "they can go any time, even when new", so I've got conflicting advice there.
Now I'm thinking of changing to Vetus low friction cables which are multi-core, on the basis that they won't just suddenly snap, leaving you with no 'pull' and thus jammed in full ahead or whatever.
Does anyone have experience of these and any comments? Why are solid 'rod' type cables apparently fitted as standard when this seems like a much better idea?
