sailorman
Which converts nicely into 1lt per 10hp per hour.
a Motor Sailor would need to be a tad over propped for obvious reasons
i would guess @ 1500 you are using around 18 > 20 of the 38hp that the 4108 will produce @ 3000rpm
But why guess when you can work out the correct fugure using a known formula?
If fuel consumption is 1.8ltrs hour then the power being produced is about 8hp.
You really should not persist in posting this erroneous information.
Just try one more time.
My 2 litre Ford Diesel cruises at 80 mph at 2100 rpm. At that speed it does 45 mpg - or 1.77galls or approx 8 litres. If I use your "formula" that means my car is being propelled by 40hp. HOWEVER it is a 138 hp engine (at 3800), so at 2100 it is producing around 80hp.
VOILA! 1litre per 10hp per hour.
IF your figure was correct I would only be getting 22.5 mpg.
So Sailorman is correct in his estimation.
And before you start saying it is not a marine engine - specific fuel consumption - that is the amount of power produced from a given quantity of diesel is pretty much the same for all small diesel engines.
Is this a correct precis of your point of disagreement?
No - at least from my side (for what it is worth) the empirical evidence from many different sources - some on this thread - support the 1l per 10hp rule of thumb. Never seen any reliable suggestions that 2l per 10hp is the norm, other than the link provided by ithet, which is not supported by any evidence.
There is such a huge difference between the two figures that one must be wrong, as I tried to illustrate with vehicle fuel consumption as this is something that is perhaps easier to understand.
The data you have produced is based on speed and distance covered which is a measure of the efficiency of using the power (dependent on prop efficiency, hull resistance, weight and then wind and sea conditions) - which do vary from boat to boat. However the amount of fuel used at particular revs/power is independent of the boat. So driving into head seas and wind will use more power for a given speed and range will be reduced.
The OP is planning a trip down to the Med through the canals. In that sort of usage, revs and power will be constant for hours on end and hourly consumption and therefore range will be constant, so we wait to hear what his experience is!
Yes, at 2000 rpm you are drawing around 20-25 hp - you can check if you have the power curves for your engine. The estimate of 1l per 10hp is pretty robust - you will also find the specific fuel consumption curve (fuel used per hp or kw) is flat from about 1700-2800, which is the normal operating range, then gets steeper as you get near max power.
Net result is that you are unlikely to exceed 2.5l hour and in the canals probably nearer 2l. How far/fast you go then depends on sea state, wind, tide etc.
My 10ton ketch does about 6kts at 2000rpm and 2.5lph
20hp per gallon is correct. 1l per 10hp is not.
Nuff said!
My 4108 doesn't use gallon an hour and does need around 25hp for cruising speed of 6kts. Its closer to .5gal.
Ianj99 - I am sure you do only use 0.5 gph, but where does your 25hp figure come from? Surely that is just another guess!
You cannot replace measurement with guesswork. There are two parameters here - power and consumption, you will not get at the correct relationship by using a guess for one of them, they both have to be measured empirically. Otherwise you will come up with any answer you want!
Jdc posted power curves for a very typical marine diesel. Why not do the calculation with the actual measured figures from those graphs? - use max power and corresponding max consumption, and then compare with the figures for say 1800rpm. You will find they both come out to a very similar gph/hp value.
The OPs headder
Consumption guesstimate perkins 4108?
