cueball
Hi, having had both... seasickness aboard a cat is much improved as when you are inside you still have almost a panoramic view out, unlike in the mono which you are very much down inside with little visibility out.
Have a look at the Woods Sagitta.
These will sail very well.
You need to get on as many different boats as possible. Try Multihull World in West Sussex since they normally have a good selection you can go on.
I am interested in a couple things which have arisen from my semi-regular trips out into the Solent this last year.
1) The Sonic drive gubbins on the older Prouts, good - bad or still ok to maintain?
2) The wife is keen on 2 x double berths in the hulls, or at least the ability to sleep 2 x couples, research puts me at least 28ft to fit that in - about right?
3) Has anyone replaced the doghouse with a nice spray hood on the Catalac (I have to say it's not aesthetically pleasing) or seen one with it replaced, curious.
4) Assuming a 30ft boat, its safe to assume we can carry as much kit on a cat of similar length? Weight distribution becomes (even more) important though.
Finally - speed. The other boat we are considering is a Sigma 36c, mainly as its a compromise. However, it's very hard to get away from the allure of the space within a cat and reading the comments above - I think if I can get 5 knots SOG (average) then I'd be delirously happy.
I suppose the only thing that concerns me now is that we see so few of them around, I guess that's due to the ratio of monohulls to multihulls in the particular area I sail.
I'm not scared of a bit of work, so we are looking around for something that's solid but need a freshen up - that should keep me occupied for a few months.
The sonic drive on the Prout cats is a fairly agricultural piece of engineering, maintenance regularly is the key to keeping it moving and keeping grief at bay. There is a real mix of metals and they just love the salty environment so they can corrode together, but keep everything well greased and oiled through each season and take things apart at least every couple of years and it should last.
L
Our 33 has two theoretical double quarter berths, cosy but ideal for youthful couples I would say, alternatively a very large single.
Speed, as you are feeling the need, I always passage plan for a 5 knot average, quite often do better which is a gamble if aiming for a tidal gate but arriving early is always better than late. Don't overload it as it will kill any kind of performance, the temptation to fill all that stowage space with useful stuff is to be resisted, I only use one water tank and rarely have it full unless cruising and unlikely to be near a tap for a while.
Main difference between sigma 36 and any of the cats is the ability to creep into the better anchorages in a cat and take the bottom as and whenever you like. It is an advantage that is not to be overlooked.
There are plenty around perhaps not around the Solent, apart from multihull world at thornham try the multihull centre at millbrook in Cornwall both usually have several that fall within your requirements on their books.
I've been doing steady research on the prices and concur that my budget would do one of 2 things - get me a semi-reasonable monohull or an older shorter cat, both of which may require some work to get back to where i'd like them. That's not such a huge deal either way.
I am hearing an awful lot of windward sailing stories, or lack of. Given that I mainly sail in the Solent and have pretty conservative expectations of where I might find myself in the next 5 years - I do worry a bit that (given the prevailing winds) I'll be motor sailing one way or another from/to my destination every trip. The inner sailor is cringing at that. The inner caravanner is loving it.
We are off to look at some in the next couple weeks, I'm prepared to be a little disappointed in my expectations of what is considered a reasonable state for boats of my budget. The jury is still out - I expect however that the family will have the last word and in order to persuade them to go sailing with me - I may have to compromise.
Unless you intend to race your boat, I reckon you could carry 50% more than a same length monohull on a cruising cat without even noticing the difference.
