Connecting to old Raymarine instrumentation
CPD
20 Sep 2006
Hampshire
Please go easy on me - I can do most things on board but NMEA isn't one of them !. I have ST60 wind and ST40 depth and speed, all going to displays in the cockpit. Old, but it works. How could I connect them into an NMEA 2000 backbone ?.
Baggywrinkle
6 Mar 2010
PaulRainbow
16 May 2016
Suffolk
The converter kit from post #2 is a good start, but we need to know what N2K kit you have and do you already have a N2K backbone/network.
lustyd
27 Jul 2010
Do you intend to keep the displays or upgrade them? I assume keep but if you’ll change them the iTC 5 is the converter you’d want. I ended up buying both as I gradually upgraded 😂
I’d happily sell you the st1 converter but it’s missing one blue terminator until I can remove the iTC5 and the terminators are quite pricey
CPD
20 Sep 2006
Hampshire
I intend to keep the current displays in the cockpit. What is your timeline on the st1 converter being fully available ?
lustyd
27 Jul 2010
haha I need to replace the wind vane so probably not quickly, but if you can find a blue terminator for a reasonable price (or someone may have a spare) you can have it for £60
CPD
20 Sep 2006
Hampshire
I intend to keep the current displays. What is your timeline on making the full st1 available ? ..........
CPD
20 Sep 2006
Hampshire
Using the ST to STNG converter and an Orca is an expensive way of getting wifi to an iPad. Some much cheaper options, for instance :
SeaTalk1 to NMEA USB Bridge YAKBITZ from UK Distributor, AVES Marine Ltd | eBay
Hi Paul, My understnding is that this device would give 1 wifi network, potentially for each parameter being measured eg depth, speed etc and any ipad (other brands available) would need to log into each seperate network to read each parameter, whereas the orca (yes on the face of it expensive) would give all parameters (and more than just the basics) in one network and potentially all on one screen. Thats how I have read it anyway. Gladl to be corrected ........... (or connected even :love::cool::love::cool::love:) ..........
ylop
10 Oct 2016
I think Paul's link may have been to a "sister" product which provides a USB link. There is a ST1 - Wifi product from the same company for < £100. It will output all the data fed to it from ST1 on one Wifi "stream". Which App do you intend to use on the iPad? Orca would work nicely if you use the Orca app but perhaps not with others? It would however add GPS, compass etc to the mix being sent to the ipad which may or may not be helpful. It will also open up the possibility to interface with an autopilot.
But I'd start with a sheet of paper and work out what you want a bit like a simplified version of Baggy's drawing above. ST1-STNG is possible but don't fall into the trap of thinking its just one cable. STNG-N2K (NMEA2000) are essentially the same electronics standards so its physical connectors that are different (so is relatively easy). But this is probably the time to be thinking about what the future looks like - spending £100 now but having no future expansion might be a PITA.
PaulRainbow
16 May 2016
Suffolk
You're correct, apologies to CPD, i linked to the wrong version.
Try this : ST1toWiFi
PaulRainbow
16 May 2016
Suffolk
Sorry i linked to the wrong version, see : ST1toWiFi
Should send all of your Seatalk data over wifi.
Well worth following the suggestion from ylop to consider what you may do in the future, before committing to buy anything now.
Dilemma
22 Nov 2017
On my boat I have the VelaNavega NMEA2 converter, Nmea2Wifi, which takes the NMEA data from my Ray ST60 network and makes it available on WiFi for Navionics running on my iPad and Android
