Connecting AIS receiver to new Raymarine Plotter
kalanka
21 Jan 2005
North West Scotland
I have a new Raymarine Element 7s plotter. I want to connect an AdvanSea AIS receiver. Can I do this using the NMEA 2000 branch off the power cable and a panel connector like this one. My previous SH plotter had the blue and green wires connecting to the AIS feed. If what I propose is feasible, do I just connect to the blue and green wires in the micro connector? Thanks
KompetentKrew
27 May 2018
NMEA 2000 must always have a "backbone" configuration like this:
You can't just wire two NMEA 2000 devices together.
This is a minimum NMEA 2000 network for connecting 2 devices:
PaulRainbow
16 May 2016
Suffolk
Your standard horizon plotter was NMEA 0183, not NMEA 2000.
Which model of AIS do you have ? Does it have NMEA 2000 ? If it does, see post #3
kalanka
21 Jan 2005
North West Scotland
Doesn't look very promising:
advanSea AIS RX-100 Receiver
More Compact than the TR200, the RX-100 outputs the received AIS data transmitted by vessels with class A and B transponders on the VHF network and displays it on an AIS compatible GPS/Plotter via and NMEA 0183 interface.
The RX-100 is also supplied with a USB cable for PC applications. (USB 2.0 38400 baud bi-directional)
Dimensions80 x 65.5 x 33.25 mm (L x W x H)
Weight200 g
Power DCDC (9.6V - 28.8V) - Average power consumption <1.5W
Peak current rating : 200mA
Electrical InterfacesUSB 2.0 38400 baud bi-directional
NMEA0183 38400 baud (output) 4800 baud (input)
ConnectorsVHF antenna connector type: SO239, 50 Ohms.
USB 2.0 - NMEA0183 / Power
Dual-channel receiverFixed frequency reception at 161.975 and 162.025 MHz
Operating temperature-25ºC to +55ºC
WaterproofnessIPX2
PaulRainbow
16 May 2016
Suffolk
Weight200 g
WaterproofnessIPX2
This will not connect directly to the Element. You will need a NMEA 0183 to NMEA 2000 converter and build an NMEA 2000 network, as shown in post #3
