jdc
That's what my Ebberspacher piping does (but it's 4mm OD not 5, not that this should make it less rigid!). Compression fittings compress an olive onto the pipe which I think will work quite well even with mildly deformable pipe provided it's round.I think you may be able to use plastic tube if it has sufficient wall thickness/ rigidity such as that supplied with an Eber' in a compression fitting.
