Usangi
Active Member
I'm a bit confused about the sail slide mast track system (is that the right terminology??) on the 1975 Jaguar 27 (bit like a Catalina 27) I've just bought. I've attached a link with a couple of photos, which should explain better than I can in writing. I couldn't seem to upload the photos.
The problem is that the sail sliders all come loose when lowering the main as there is no mast gate. But if I installed a mast gate, the sail wouldn't come down to the boom as there is a separate track.
So what happens is that as I raise the main I need to feed the sail sliders into the track which is quite fiddly. There is a little metal thing that is meant to swing loose (and generally does although it often gets stuck) which allows the slider to go up but won't let it go down again. This is fairly helpful but its not great.
When I lower the sail, what should I be doing? Should I be taking the sliders out of the main track and then feeding them into the bottom track? It all seems a bit of a palaver, truth be told! Anyone else have a similar system or any solutions?
