Twister_Ken
Yes, Vectran is the dacron suggestion.
Radial vs x-cut seem like opposites to me.
Bumped into your friend the other day, had a chat about this, and I recommended Kemps. Do you know if he contacted them, yet?Should have said, boat concerned is not my Twister, but a brand new boat with a high aspect main and a fractional skinny genoa, that a close friend is buying, with a view to fast cruising, not racing.
I am also anti-socks. My genoa had which was a bit tired, and a pain in the aris even with no wind. Had a new one made which didnt fit, so handed it back and asked for a UV strip instead - it's no hassle, so why not, IMHO.My experiance with the "sock" is that it can be a nightmare in galeforce winds. They are generally not a tight enough fit, so you have to have a line wound around the outside to effectively tighten it up. They are a pain in the arse. I have seen them literally flapping the boat apart in a bad gale. Also if you are in sunny climes you will not be bothered to put it up when you are anchored, and your sails will disintegrate much faster from UV.
I would change the order at once, and get a strip put on.
