Zippysigma
Need a new furling genoa for cruising, but often need to reef right down as my lifting keel makes the oceanis a little tender and needs early reefing, but I will sail in 25kts.
One local SM said to only use high modulus Dacron as laminate will delaminate when rolled tightly around the forestay in high winds and they never fit luff foam. They reckoned that Dacron would last at least 5 seasons with no loss of shape. Another said that laminate is fine and they would always recommend luff foam.
Also, is high modulus Dacron the same as higher weight? eg. 5.9oz HM compared to 7.4oz?
Errr....... any suggestions?
