Buck Turgidson
Surely the problem is that the flow regime sails work in is very different from those an aircraft wing operates in? After all, flow velocities round a sail will be tens of MPH at most. If it gets to 100 MPH, must of us would be under bare poles! Even low performance aircraft are operating at higher flow-rates than that, and that's what your average aerodynamicist will be used to.
FWIW, my understanding was that a rig with two sails will get closer to the wind because the slot effect between the sails accelerates the air-flow across the back of the after sail., thus increasing the lift experienced by the after sail. So, I tend to follow the "lift" way of thinking of how sails operate. I also suspect that flow separation at the leading edge is important in defining the different path-length - I suspect the flow on the windward side of the sail is detached from the sail, and that on the leeward side is attached. But I'm NOT an aerodynamicist!
Bernoulli still applies even at low velocities. delta P may be small but the area is big.
