RIN
The compressor on our starboard KAD32 came on as soon as we started the engine. Trying to work out what was wrong we swapped over the relay inside the control unit with the one in the port engine - no change. Then swapped over the control module - no change. Then swapped over the microswitch (magnetic) that senses you have pushed the the throttle fully down and a result - it was now the port engine compressor that came straight on, with stbd compressor behaving normally Trots off to buy a replacement see here
And was told £128 QUID - Politely declined to purchase microswitch
Question 1 Can this be true - it seems a ridiculous price
Then thought if I don't reconnect the switch, the compressor will just come on anyway at 1500 rpm so I probably don't need to spend the £128. So I left it off and restarted the port engine but the compressor came on straight away So now I am not sure anymore that it was the microswitch.
Question 2 I would have thought with the switch disconnected it should not have come on until 1500 revs is this right or have I missed something?
